Mrpenguinz
Mar 25, 2022Aspirant
NightHawk XR700 GAMING ROUTER R-Apps not loading.
It's now 2022 I'm still having same problem that is "This R-App is not loaded yet, please try again in a minute." None of the R-Apps ever load Geo - filter, Qos, Device Manger, Network Monitor, Hybri...
Netduma-Fraser
Mar 26, 2022NetDuma Partner
Try the beta firmware instead, once upgraded, factory reset, wait 2 minutes then access and see if it works:
https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/XR700-DumaOS-3-0-Beta-Firmware/m-p/2019958
- PaulginsAug 26, 2022Aspirant
Do you have good solution and excellent feedback for R-Apps not loading? Because 'trying beta 3.0' with factory reset is the last thing i would like to 'try'. Unless you are sure that issue is solved. Or is Beta enough tested after two years having this issue.
It's pain full.
- Netduma-FraserAug 27, 2022NetDuma PartnerA more permanent fix is coming with the next firmware version, the suggestion above or going to the System Information page and then clicking on Rapp panel menu (≡) and changing the retries to 5, then rebooting from the interface and waiting 2 minutes before accessing are the best options currently.
