Mrpenguinz
Mar 25, 2022Aspirant
NightHawk XR700 GAMING ROUTER R-Apps not loading.
It's now 2022 I'm still having same problem that is "This R-App is not loaded yet, please try again in a minute." None of the R-Apps ever load Geo - filter, Qos, Device Manger, Network Monitor, Hybri...
Paulgins
Aug 26, 2022Aspirant
Do you have good solution and excellent feedback for R-Apps not loading? Because 'trying beta 3.0' with factory reset is the last thing i would like to 'try'. Unless you are sure that issue is solved. Or is Beta enough tested after two years having this issue.
It's pain full.
Netduma-Fraser
Aug 27, 2022NetDuma Partner
A more permanent fix is coming with the next firmware version, the suggestion above or going to the System Information page and then clicking on Rapp panel menu (≡) and changing the retries to 5, then rebooting from the interface and waiting 2 minutes before accessing are the best options currently.
