Viperlocc
Nov 04, 2019Guide
nighthawk xr700 gaming router wont connect to external hard drive on readyshare
This was working without a problem for almost a year now and all of the sudden when I try to connect to the shortcut for the external hard drive through readyshare I get an error saying "The drive or...
Netduma-Fraser
Nov 06, 2019NetDuma Partner
Sorry to hear you're having this issue. It may be best for you to create a ticket with Netgear directly: http://support.netgear.com/ just to double check though, this was an issue on the previous firmware and this newest firmware which actually included a Plex update as well?
- ViperloccNov 06, 2019Guide
thanks for your reply
I had this problem come up on a older firmware and when the next update came out it fixed the issue which was the update I was running that the issue has now come back on. The new update that I just installed didnt fix the issue this time so not sure myself what is going on.
As for a ticket I have had the router for 1 year now and it has been replaced 1 time already but I believe that they will tell me the warranty is up and there is nothing that they can do which to me is sad for only getting 1 year for a router that we spend $500 on
- Netduma-FraserNov 06, 2019NetDuma PartnerSorry to hear that, I'd suggest doing a factory reset if you haven't already on the new firmware as that can prevent legacy issues carrying over. Considering the new firmware has a Plex update I would definitely suggest that so it is running that update properly.
- fibricNov 23, 2019Initiate
Have the same issue since updating to v1.0.1.20.
It doesn't detect my 20TB USB3 drive. I partitioned the drive to 5 4GB drives because I think, I read in some older postings somewhere that the max partition size is/was 4GB. I also deleted 4 of the 5 partitions to check if at least one 4GB partition is detected -- but no luck.
I did a factory reset as well.
My XR700 doesn't detect the drive.
I hear the HDD's spinning up when unplugged and plugging in the USB3 cable, but my drive never shows up again in the ReadySHARE settings page.
My drive is formatted in HFS+ because I used it for wireless Timemachine backups. Now my Mac Pro and MacBook Pro regularly show the information of how many days no backup's done.
