Vegas8889
Aug 18, 2020Aspirant
Nighthawk xr700 not connecting to all devices
Earlier today, I had power go out on the router for about 3 minutes. When it kicked back on, it was connecting to probably about half the devices in the home and was providing internet. The other item...
Netduma-Fraser
Aug 19, 2020NetDuma Partner
On one of the devices you're seeing the issue on 'forget' the WiFi and then try reconnecting by reinputting the WiFi password. Does it get a connection properly then?
Vegas8889
Aug 19, 2020Aspirant
I’ve tried that. It doesn’t work
- Netduma-FraserAug 19, 2020NetDuma PartnerUpgrade to this firmware and see if it works then: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
- Vegas8889Oct 30, 2020AspirantHello,
Sorry, I never saw this message pop up from a few months ago, and the devices all randomly connected over night so I just wrote it off.
However, last night it had me update to v1.0.1.34 and it’s doing it again— except this time nothing reconnected over night. Any new recommendations?- Netduma-FraserOct 30, 2020NetDuma PartnerYou could try installing the firmware again via TFTP and then doing a factory reset, that would make it the freshest install possible and may help: https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
