Big__Rossatron
May 15, 2020Tutor
Nighthawk XR700 Problem detecting internet connection
Hi, Got my XR700 today to replace an ASUS AC88U I have Vodafone Gigafast and I was running my Asus directly into the fibre box with no issues, when I try to connect my XR700 the setup wizzard...
Netduma-Fraser
May 16, 2020NetDuma Partner
Do you know if you require PPPoE or VLAN? If you go to Internet Setup and set it to dynamic and test the connection does that allow it to work? If not reboot the router first then reboot the fibre box, if that doesn't work boot them in the opposite order. Sometimes they're specific about how they want to be booted to establish a connection.
