Jim_Albani
May 11, 2020Guide
Nighthawk XR700 VS XR500 Inquiry
This question is more of an inquiry than anything else.... Originally I was going to hold off and order the Nighthawk XR700 from netgear, but ended up buying the XR500 instead since the price was mod...
Jim_Albani
May 11, 2020Guide
Thanks for the response, and I also have to appologize forgetting that the EA9500 was a triband... That was something I completely overlooked. What would possess me to think the Guest Network was a sepperate band is beyond me... Your solution might be the answer I was looking for... This would help me by not having to spend more money on hardware and possibly help me achieve the same goal as I was trying to.. As mentioned, I'm extremly impressed with the XR500's GUI and really don't want to loose that as it's proven alrealy to be very benificial.. Just one extra question regarding this, would I be wise to disable the WIFI on the XR500 if the EA9500 is being used as an access point ? I live in an appartment, so I'm not adding an access point to extend the network for distance, but to also give me 8 extra ethernet ports to use.. Unfortunatey I wont be able to give you a respones back on the solution right away due to the fact that I'm going to be tearing this system apart in the next couple of weeks to clean everything (IE:Running wire channels to hide the wires and give this room a new coat of paint) But I will follow up at a later date to let you know how it all worked out.. Once again, I thank you for your advice... It's muchly appreciated..
May 11, 2020Guru - Experienced User
Yes you can do that with the Linksys router.
