Dysfunctioned_L
Nov 10, 2018Follower
Nighthawk xr700
Hello,
I have bought the Nighthawk XR700 pro gaming router yesterday and tried to set it up earlier today, it seems that everything ok in regards of the setup with the DumaOS software ( haven't don...
Netduma_Jack
Nov 11, 2018NetDuma Partner
That's odd. How are you connecting the XR700 exactly? It should just be an ethernet cable from your modem (the one your ISP gives you) into your XR700's Internet port.
Contact NETGEAR official support if you're not able to fix it https://www.netgear.com/support/contact.aspx
