Dysfunctioned_L
Nov 10, 2018Follower
Nighthawk xr700
Hello,
I have bought the Nighthawk XR700 pro gaming router yesterday and tried to set it up earlier today, it seems that everything ok in regards of the setup with the DumaOS software ( haven't don...
Altsai
Nov 14, 2018NETGEAR Expert
but it's not connecting to the internet, it keeps telling me that there is no ethernet cable connected to the internet port while there is, I have done a loop test on my LAN cable and it worked.
>>>>> does your ISP require any special settings? e.g., VLAN or DHCP option 61 or?
Has anyone faced this problem? if so can you tell me how you solved it ? (I live in the UK and don't have a modem I just plug my LAN to a socket in the wall)
Furix
Dec 27, 2018Aspirant
This answer might be late...
I had the same issue as you describe. I had to call my ISP and have them «activate» their connection to my new XR700 - after this it works like a charm. It turned out my ISP had locked the connection to my previous router, so they had to clear that one out and reenable the connection to my new XR700.
Cheers!
Cheers!
- FURRYe38Dec 27, 2018Guru - Experienced User
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the NG router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the NG router gets from the modem.
Cheers!
