XrXs
Jul 05, 2019Aspirant
Nighthawk xr700
Hello i need help with XR700 on the Geo-filter page when i had the auto ping unchecked i hit the X on the bottom right for where i can se the people or servers i connect to or with, i cant get it back...
Jul 05, 2019Guru - Experienced User
What FW version is loaded?
What browser are you using? Try a different browser.
XrXs
its allways that way in this forums :) what do u have. I fixed the problem, now im hinna figure out why it finds player outside my ratius
- Netduma-FraserJul 05, 2019NetDuma PartnerGlad to hear you resolved it, the likely cause of players outside your radius is become you have Ping Assist enabled in the Geo-Filter Map options. This will find games under your ping limit even if it is outside the radius so you don't miss the opportunity of a good game - if they appear with dashed circles around them they have been ping assisted.
