Imitable
Feb 13, 2020Aspirant
Nighthawk
Anyone else having any problems trying to change the nat type from strict to open?
Feb 13, 2020Guru - Experienced User
What problem are you having?
What router are you using?
Firmware on that router?
What modem are you on?
Maybe explain exactly what you're trying to do and why you're trying to do so. This will let us to help you better.
Imitable
The router I am using is the AC2400 and the modem is the AC1900
The problem that im having is that when I try to play any of the call of duty games my NAT type is set to strict instead of open.
- plemansFeb 13, 2020Guru - Experienced UserNeither of which are model numbers. But from the sound of it you're in a double nat. Is the router in ap mode or the modern in passthrough mode?
- ImitableFeb 13, 2020AspirantThe router is in Ap mode.
What specific devices are you using? AC2400 and AC1900 are speeds, not models.
Firmare on them?
What are you playing call of duty on?
PS4, Xbox, Pc?
And is it wireless/wired, how is it connected?
And then is it connected via the AP device (which is?) or the primary router?
Is it the only game with issues?
