Mikey_h
Mar 24, 2022Follower
Nighthawk
I have a 1gb Internet speeds but when I’m on Lan I doesn’t give that speed only 470 but when I test it via Wifi I get 970
Netduma-Liam
Mar 25, 2022NetDuma Partner
Good answer above from plemans.
Could you also please confirm how you're testing these speeds? Are you using the built-in Connection Benchmark, or are you using a third-party speed test such as speedtest.net?
Do you have QoS enabled and configured? If you disabled QoS from the three-line menu in Congestion Control, do your speeds return to normal?
