beatlebob
Jun 29, 2020Aspirant
Nighthwak XR450
I just installed the xr450 to my existing router and made it AP mode. It is still showing as a separate router and I can't do any updates to the router. The set up in settings in blacked out. It i...
beatlebob
Thanks. I want to make it a bridge on my existing router
Netduma-Fraser
Jun 29, 2020NetDuma Partner
If you want to do that then access the other router and enable bridge mode to the XR.
- beatlebobJun 29, 2020Aspirant
Thanks. I will have to figure that out
I am now getting a flashing orange light on the router. I looked on line and shut it down for over thirty minutes and still no good. Is there any way to put back to factory settings without logging into it since I can't log in?
- Netduma-FraserJun 30, 2020NetDuma PartnerI'm not sure what router you've enabled bridge mode on but it should have a reset button you can hold down in the back of it to do so.
