ATOMINSF
Dec 03, 2020Tutor
No Access Control on XR1000
The R7000 had something call Access Control. The XR1000 does not. If someone were to get access to a ethernet cable they will be able to access your network. Example, you have an IP security camer...
michaelkenward
Dec 04, 2020Guru - Experienced User
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
