ipponz
Jan 09, 2020Aspirant
No Difference With or Without Nighthawk XR500 in Modern Warfare
I have bought a Nighthawk Pro XR500, specially for FPS games. Untill now i really can't see any difference with or without this router. At this moment i'm playing Call of Duty Modern Warfare and alm...
Netduma-Fraser
Jan 09, 2020NetDuma Partner
The UK server you're probably talking about (with the white circle) is an authentication server required for online play, it's not your game server. Could you attach a screenshot of the Geo-Filter with what you see when you're in a game please? What is the average ping you're getting on the Geo-Filter shown by Auto-Ping? Also have you followed our optimal settings guides? I would do that first if you haven't already: http://support.netduma.com/en/support/solutions/folders/16000090646
ipponz
Hier is another auto ping to Call of Duty Modern Warfare from my Netgear Gaming Pro router.
Can it be that i receive the information to slow? Or is it something else?
- Netduma-FraserJan 09, 2020NetDuma PartnerNo that information is fine and looks like you have a good ping. Only one of those lines are ping, the rest are other statistics. You should be able to see a ping number instead above the graph that will be easier to read. Could you provide a screenshot of the map itself when you're in the game? If you go through the optimal settings guides it will help you understand the router more and how to use it more effectively.
- ipponzJan 09, 2020Aspirant
The previous screenshots were made, when i was in the game. That's why i asked if my receive rate was too slow. I just don't understand it. Even when i pre-fire i lose the gunfight. No matter which weapon. My son had a couple of friends playing MW at our house and they all say the same. I have some normal matches, where my bullets actually do damage, but maybe 1-in-7 matches.
- Netduma-FraserJan 09, 2020NetDuma PartnerThat's just the ping panel, I'd like a screenshot of the map as well please how that looks when you're playing a game. Have you setup QoS according to the optimal settings guide?
