drake8602
Nov 25, 2018Star
No ethernet connection on XR500 after upgrading from N600
So yesterday I decided to upgrade my router to the XR500. I originally had the following setup:
Arris Modem (Spectrum)>>N600>>Netduma R1 This setup worked flawless for me for a couple years....
drake8602
Dec 03, 2018Star
Sorry in the delay getting back to this. I disconnected all the ethernet connection to the XR500 and when back through the setup wizard. After complete, I started connecting each device one at a time. I narrowed down the issue as happening when I plugin my 8 port Netgear switch. Not sure if I have something connected to the switch that is causing an IP conflict or what, but that is when my connection drops. I need to connect the switch with nothing connected to it, and go through each connection one at a time, but for now my XR500 is working like a charm! I appreciate all the feedback!
- FURRYe38Dec 03, 2018Guru - Experienced User
What is the model of the NG swtich? Managed or non managed? Non managed is preferred.
- drake8602Dec 03, 2018Star
It is unmanaged: TL-SG108
And after double checking I stand corrected, this is a TP-Link switch not a Netgear.
IF this this one:
https://www.tp-link.com/us/products/details/cat-42_TL-SG108.html
Probably Green Ethernet technology saves the power up to 82%
or Support 802.1p/DSCP QoS1 and IGMP Snooping functionmaybe the cause when this switch is used. Seen this before with this Green Ethernet feature.
If you need switches, I recommend NG GS non managed series or D-Links DGS-105/108 series.
