GalaxyAndroid
Apr 09, 2019Guide
No hace ping el Geofiltro cuando entro a Fortnite
Buenas tardes comunidad netgear, he adquirido ya hace tiempo un Net Gear XR500 y con mi conexión de fibra hacía ping perfecto, luego vino una mudanza y ahora dispongo de conexión radio 4G. He resetead...
- Apr 10, 2019
Follow these steps please:
1. Go to the Device Manager.
2. Click on your Gaming PC.
3. In the new panel that opens, change the device type to a PlayStation.
4. Go to the Geo-Filter.
5. Delete your PC from the top Geo-Filter panel if you have added it previously.
6. Now add your PC. It should automatically be added with the 'console' service.
7. Decide if you want to use Filtering Mode or Spectating Mode (see our Geo-Filter guide if unsure)
Your Geo-Filter will now show your PC game(s) server when you next play. To setup your Geo-Filter optimally, please see this guide
GalaxyAndroid
Apr 09, 2019Guide
Thanks for your reply, i´ve read the guide and followed the steps but i cant see the icons of servers or players and ping is not show either... im afraid its a problem with the last firmware
Netduma-Fraser
Apr 09, 2019NetDuma Partner
You will only see the server once you load in to the game (make sure you've got the map zoomed out all the way), you won't see players. Have Auto Ping enabled in the Geo-Filter Map options.
- GalaxyAndroidApr 09, 2019GuideYeah, I know it's only showing in game. But doesn't work for me anymore... I don't know what's happening with this feature but I lost it
- Netduma-FraserApr 09, 2019NetDuma PartnerCan you take a full screenshot of the Geo-Filter page please when you're in a game, even if there's nothing on the map
Sure, here are the images (in game mode) i am trying with fortnite but with apex and CoD its the same. I also tried with filtering mode but nothing works... Is it possible it happens due to my poor connection? But in my mind i think that doesn´t matters...
