Jumbokoooookie
Aug 03, 2019Guide
No high priority ddetected (no red light)
i got my new router yesterday and when i first set it up it was detecting high priority traffic and working as expected, today it shows no detection (no red light) and also shows no high priority pac...
Netduma-Fraser
Aug 13, 2019NetDuma Partner
Have you disabled QoS in the Anti-Bufferbloat menu? If so that will be the reason why it isn't working.
Jumbokoooookie
Aug 13, 2019Guide
QoS is enabled and still doesnt detect anything. it worked when i first set it up but now it doesnt. this is the traffic priorotization section while fortnite is open.
- Netduma-FraserAug 13, 2019NetDuma PartnerCan't see the picture at the moment as it hasn't been moderated. Are you playing Fornite on PC or console? Have you tried using the console service to see if it works that way?
- JumbokoooookieAug 13, 2019Guide
playing on PC where would i find the console service to see if it has any affect?
- Netduma-FraserAug 13, 2019NetDuma PartnerAdd a manual service to Traffic Prioritization and just click 'Console'.
