Xenos8
Nov 16, 2020Apprentice
No Internet After Reboot
I've notice that my XR500 can't seem to find an Internet connection when it reboots. Whether I perform the reboot (and reboot of modem) or after a power failure. I learned a little trick that if I ...
Netduma-Fraser
Nov 16, 2020NetDuma Partner
Sometimes it can be finicky to establish the connection, if you set static details then it should be much quicker.
Xenos8
Nov 17, 2020Apprentice
Can you explain static details? I receive my IP from my ISP via DHCP.
- Netduma_AlexNov 17, 2020NetDuma Partner
Take a look at the automatic details, do they change every time you reboot? If not, you could just copy those details in and make them static.
