Bulldaw6
Jun 24, 2020Guide
No Internet after router reboot
I rebooted my router and had no internet acess upon reboot. Contacted ISP and they could see the mac address was conntected but it turns out it was my desktop. So during the reboot, the router allowe...
Netduma-Fraser
Jun 24, 2020NetDuma Partner
In Internet Setup did you change the MAC address to use this computer MAC address? Go through the Setup Wizard on the XR to try and re-establish the connection.
- SilenciousJul 19, 2020Aspirant
On reboot of router makes wifi is unvailable. I have to resort to reboot my ISP provided router to reconnect. Firmware version:1.01.20 Can you assist?
- Netduma-FraserJul 20, 2020NetDuma PartnerHas your initial issue been fixed? Upgrade to this firmware, then perform a factory reset and see if your issues are resolved: https://kb.netgear.com/000061714/XR700-Firmware-Version-1-0-1-24-Hot-Fix
