Terminator68622's avatar
Oct 20, 2018
no Internet on AC1900 modem router
I just bought this AC1900 modem router and cannot get it to set up either automatically or manually, I am posting this using the ISP supplied router, the VLAN  ID isn't accepted and for some settings I have to change from VDSL to ADSL then switch back to VDSL. Only one was simple the MTU set to 1480 no problem
I use Origin as my ISP, my last netgear modem router I gave to my brother and he's been using it for 10 years. Does anyone know the settings for this modem router for this ISP? Or how to get it working with my ISP.
  • It's OK I got it connected I just reset it and when it asked for VLAN ID I put in 101 and it set itself up automatically. I had never had it ask for that before this morning so it's OK now
