csaum
Oct 24, 2018Tutor
No Internet on LAN Ports WiFi fully connectivity
Only wifi seems to be working on the router, DHCP is not giving my Ethernet ports a correct address. My pool is set at 192.168.1.x but the ip it gives my actual devices is 169.x.x.x now rebooting th...
csaum
Oct 24, 2018Tutor
The only devices I have connected are the Xbox one X and the PC wired (through a wiring closet the apt. I am in has eports thoughout and a small switchboard for a router to be patched into) and an Google home wirelessly connected. It still says that it is connected to the network but isn't able to retrieve a ip from the router. I will change the pool as you asked tonight.
I will attempt your fix and get back to you!
Oct 24, 2018Guru - Experienced User
Can you take the remove this patch panel and internconnecting temporarily and test with out it? Trying to see if anything else you may have connected could be causing problems.
- Netduma_JackOct 24, 2018NetDuma Partner
A couple of other things to try:
- Do you have static IP on either your console or PC?
- If you connect them wirelessly, what IP address do they get assigned?
- csaumOct 29, 2018Tutor
I tried it with a static IP on both inside the pool we setup as well as outside and they stay with that but stil lose network config.
- Netduma-FraserOct 29, 2018NetDuma PartnerI've sent you a PM csaum, please see if that resolves your issue.
