csaum
Oct 24, 2018Tutor
No Internet on LAN Ports WiFi fully connectivity
Only wifi seems to be working on the router, DHCP is not giving my Ethernet ports a correct address. My pool is set at 192.168.1.x but the ip it gives my actual devices is 169.x.x.x now rebooting th...
SamuraiX3000
Jan 17, 2019Aspirant
I'm experiencing the same issue, is there a fix or workaround. I only had this router for 1 day and I'm getting ready to retun to Best Buy. My desktop gets a 169.xxx.xxx ip address for about 3 minutes after boot-up and my Nest cameras keep getting disconnected randomly through out the day. My old Nighthawk R7000 had better Wi-fi connectivity.
- FURRYe38Jan 17, 2019Guru - Experienced User
What FW is currently loaded?
What is the Mfr and model# of the ISP modem the NG router is connected too?How is your PC connected? wireless or wired?
- Netduma-FraserJan 17, 2019NetDuma PartnerI'd advise you rollback to the firmware ending .20 and see if that resolves it
- Ped0016Jan 23, 2019Aspirant
I seem to be experiencing a similar issue I have my Xbox one X wired in to port 1. If I power cycle my router the port works normally but when I shut off my Xbox for the night and turn on the next day. It the Xbox will no longer be connected to the internet, when I try to connect Xbox gives me error message cant connect to router/internet. I the have to restart my router for the port to work again.
Wireless seems to be unaffected and works fine.
really hope can help with issues this router is too expensive to be having issues like this :(
I also switch my Xbox for. The instant on mode to the energy save mode just encase that is the issues since I seen there is a issue with the Xbox’s and this router when in that mode.
