navigent2
May 30, 2019Guide
No Internet on LAN Ports WiFi fully connectivity
I have full connectivity via Wif; however, I cannot connect to anything via the LAN. If I turn off wifi on either of my macbooks, I am not able to access the internet at all. My synology backup alo...
- May 30, 2019Okay that's very strange it happened then, let us know if it happens again after a reset.
May 30, 2019Guru - Experienced User
Swap LAN cables?
is the LAN port LEDs blinking at all with a device conntecte?
Try a factory reset and setup from scratch...do the LAN ports come alive after that?
Try a FW downgrade to v32...
- Netduma-FraserMay 30, 2019NetDuma PartnerDo you have any consoles connected running in instant on/standby modes at all? If so disable those features and then reboot the router, does that resolve the issue?
- navigent2May 30, 2019Guide
No devices in stand by.
LAN cables are new and LEDs are blinking as if there is activity. I will try the factory reset and set it up again.
- FURRYe38May 30, 2019Guru - Experienced User
:smileyhappy:
- Netduma-FraserMay 30, 2019NetDuma PartnerOkay that's very strange it happened then, let us know if it happens again after a reset.
