navigent2
May 30, 2019Guide
No Internet on LAN Ports WiFi fully connectivity
I have full connectivity via Wif; however, I cannot connect to anything via the LAN. If I turn off wifi on either of my macbooks, I am not able to access the internet at all. My synology backup alo...
- May 30, 2019Okay that's very strange it happened then, let us know if it happens again after a reset.
navigent2
May 30, 2019Guide
LAN cables are new and LEDs are blinking as if there is activity. I will try the factory reset and set it up again.
May 30, 2019Guru - Experienced User
:smileyhappy:
- Netduma-FraserMay 30, 2019NetDuma PartnerOkay that's very strange it happened then, let us know if it happens again after a reset.
- navigent2May 31, 2019Guide
Reset worked. Very odd.
- FURRYe38May 31, 2019Guru - Experienced User
Glad the reset worked. Let us know if that happens again. If it does, the unit may need to be RMA. LAN ports should not fail.
Enjoy. :smileywink:
- navigent2Jun 01, 2019Guide
Unfortunately, the fix is short lived. I disconnected my laptop and reconnected with no LAN connectivity. It appears that if I disconnect or device goes into sleep mode, it breaks. This router worked after initial setup for a few months. I did nothing to change anything. Not sure what else to do at this point. My opinion of Netgear is very low at this point.
