navigent2
May 30, 2019Guide
No Internet on LAN Ports WiFi fully connectivity
I have full connectivity via Wif; however, I cannot connect to anything via the LAN. If I turn off wifi on either of my macbooks, I am not able to access the internet at all. My synology backup alo...
- May 30, 2019Okay that's very strange it happened then, let us know if it happens again after a reset.
Jul 30, 2019Guru - Experienced User
I would returne the unit and get another or ask NG support for a RMA.
- Netduma-FraserJul 30, 2019NetDuma PartnerHave you tried the alternate options mentioned on the community such as using a switch?
- PieCaptainAug 06, 2019Guidequick update. I've been running the hotfix for a few weeks now (since my last comment) and I still have to reboot daily. Running through another switch doesn't make a difference, my devices running through my switch also lose connectivity The one thing I haven't tried yet is resetting, but I need to do that when I remember at a convenient time, not when I'm driving to work!
- FURRYe38Aug 06, 2019Guru - Experienced User
Let us know if a factory reset and setup from scratch results in something different.
