navigent2
May 30, 2019Guide
No Internet on LAN Ports WiFi fully connectivity
I have full connectivity via Wif; however, I cannot connect to anything via the LAN. If I turn off wifi on either of my macbooks, I am not able to access the internet at all. My synology backup alo...
- May 30, 2019Okay that's very strange it happened then, let us know if it happens again after a reset.
Netduma-Fraser
Jul 30, 2019NetDuma Partner
Have you tried the alternate options mentioned on the community such as using a switch?
PieCaptain
Aug 06, 2019Guide
quick update. I've been running the hotfix for a few weeks now (since my last comment) and I still have to reboot daily. Running through another switch doesn't make a difference, my devices running through my switch also lose connectivity The one thing I haven't tried yet is resetting, but I need to do that when I remember at a convenient time, not when I'm driving to work!
- FURRYe38Aug 06, 2019Guru - Experienced User
Let us know if a factory reset and setup from scratch results in something different.
PieCaptain wrote:
quick update. I've been running the hotfix for a few weeks now (since my last comment) and I still have to reboot daily. Running through another switch doesn't make a difference, my devices running through my switch also lose connectivity The one thing I haven't tried yet is resetting, but I need to do that when I remember at a convenient time, not when I'm driving to work!- PieCaptainAug 30, 2019Guide
another update!
I've not had a chance to do the factory default settings yet, HOWEVER, i haven't had to reset the router for 6 days!
I noticed V2.3.2.56 is now available, but he patch notes suggest it doesn't address this issue, so i am reluctant to upgrade to this version just yet- Netduma-FraserAug 31, 2019NetDuma PartnerThat's great to hear! Yes probably best to keep it on the version you're on at the moment and if it happens again then update to see if that helps.
