TwistedVet
Mar 24, 2021Aspirant
No Internet
This may have been anwsered before but I couldn't get a search result to assist me. I just bought a XR500 and cannot get a connection to the internet (no LED) showing. Spectrum ISP w/ en2251 modem ...
TwistedVet
[admin login] from source 192.168.1.2
[DumaOS] Ubus object 'com.netdumasoftware.geofilter' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.hybridvpn' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' now bound
[DumaOS] config write 'com.netdumsoftware.geofilter.settings'
[DumaOS] No settings file, restoring.
[DumaOS] Geo-Filter cloudsync result 'false','All mirrors are down'
[DumaOS] Ubus object 'com.netdumasoftware.rappstore' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.qos' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.devicemanager' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.desktop' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.autoadmin' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.neighsync' added, attempting to bind pending
[DumaOS] App 'com.netdumasoftware.rappstore' initialised & starting.
[DumaOS] R-App store cloud sync failed
[DumaOS] HTTP download failed with code 'host or service not provided, or not known'
[DumaOS] applying qos for zone lan
[DumaOS] applying qos for zone wan
[DumaOS] Resync R-App store cloud
[DumaOS] NSS delete root for interface 'br0'
[DumaOS] NSS delete root for interface 'brwan'
[DumaOS] config write 'com.netdumasoftware.hybridvpn.settings'
[DumaOS] Backing up settings to config partition.
[DumaOS] Ubus object 'com.netdumasoftware.dpiclass' now bound
[DumaOS] Dependency loaded 'com.netdumasoftware.devicemanager'
[DumaOS] All dependencies loaded, starting
[DumaOS] Cloudsync DPI result 'false','All mirrors are down'
[DumaOS] App 'com.netdumasoftware.desktop' initialised & starting.
[DumaOS] Cloudsync Themes result 'false','All mirrors are down'
[DumaOS] config write 'com.netdumasoftware.desktop.database'
[DumaOS] config write 'com.netdumasoftware.devicemanager.dpisettings'
[DumaOS] config write 'com.netdumasoftware.devicemanager.database'
[DumaOS] Dependency loaded 'com.netdumasoftware.autoadmin'
[DumaOS] Ubus object 'com.netdumasoftware.networkmonitor' added, attempting to bind pending
[DumaOS] App 'com.netdumasoftware.neighsync' initialised & starting.
[DumaOS] App 'com.netdumasoftware.geofilter' initialised & starting.
[DumaOS] Waiting for 'com.netdumasoftware.autoadmin' to run before starting
[DumaOS] Waiting for 'com.netdumasoftware.devicemanager' to run before starting
[DumaOS] pending subscription for package 'com.netdumasoftware.dpiclass'
[DumaOS] pending subscription for package 'com.netdumasoftware.devicemanager'
[DumaOS] App 'com.netdumasoftware.hybridvpn' initialised & starting.
[DumaOS] App 'com.netdumasoftware.devicemanager' initialised & starting.
[DumaOS] subscribe to 'com.netdumasoftware.neighwatch' from 'com.netdumasoftware.devicemanager'
[DumaOS] App 'com.netdumasoftware.qos' initialised & starting.
[DumaOS] App 'com.netdumasoftware.networkmonitor' initialised & starting.
[DumaOS] Ubus object 'com.netdumasoftware.procmanager' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.neighwatch' added, attempting to bind pending
[DumaOS] Ubus object 'com.netdumasoftware.systeminfo' added, attempting to bind pending
[DumaOS] App 'com.netdumasoftware.procmanager' initialised & starting.
[DumaOS] Non-existent publish method 'licence_permitted'
[DumaOS] App 'com.netdumasoftware.neighwatch' initialised & starting.
[DumaOS] DHCP new lease allocated.
[DumaOS] DHCP new event.
[DumaOS] subscribe to 'com.netdumasoftware.arpwatch' from 'com.netdumasoftware.neighwatch'
[DumaOS] App 'com.netdumasoftware.systeminfo' initialised & starting.
[DumaOS] Starting process manager
[Initialized, firmware version: V2.3.2.114]
Netduma-Liam
Mar 25, 2021NetDuma Partner
If you go to System information on the XR500, is it showing a WAN IP from the router?
If not, are you able to see any information about the XR500 on the admin interface for your modem?
- TwistedVetMar 25, 2021Aspirant
no WAN ip it's 0.0.0.0
- Netduma-LiamMar 25, 2021NetDuma Partner
Just to be clear, are you seeing this in System Information? Your previous screenshot shows networking settings.
Could you connect directly to the spectrum modem and go to 'Manage users' and see if you can see the XR there?
I do not have access to this modem (spectrum), I would love to change some things spectrum changed their firmware supposedly. From what I can read this modem doesn't asign ip to routers, not sure if I was reading it right. Can I manually put in an IP, IP subnet, and so on and where would I get that info?
