djarrett53
Dec 09, 2020Follower
no over the channels on tv
when nighthawk is on i lose the over the air channels using a amazon rect dvr on the tv.
michaelkenward
Dec 10, 2020Guru - Experienced User
You might like to tell us what you are doing and where it goes wrong.Error messages and stuff like that.
You could also explain what you mean by "amazon rect dvr". What is it and what does it do?
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
I will ask the Netgear moderator to move your message.
schumaku
DIRECTV DVR with OTA probably?
Using a wireless HDMI connection to your TV?
- michaelkenwardDec 10, 2020Guru - Experienced User
Who knows?
djarrett53 is splattering this place with enigmatic messages:
when nighthawk xr 500 is on it blocks my over the ...
Connect router to cat5 cable to smart TVs
