Ejzerwas
Nov 07, 2022Tutor
No ping heat map
So I can't get call of duty ping heat map to load. No servers show up in the map. But when I target other games servers will show up on the map. No idea where to start to fix this issue?
Netduma-Liam
Nov 17, 2022NetDuma Partner
Can you resync cloud and check again? They should be updated now.
SPLIF
Dec 27, 2022Aspirant
I purchase the xr1000 over the weekend. All game servers are working on the ping heatmap except the warzone/ cod servers. It's the only game I play. I can't use the geo filter because I have no clue where the best servers are to mark them on the map. Any fix?
- Netduma-FraserDec 27, 2022NetDuma PartnerIt needs a cloud update which we'll do as soon as we can, it will not affect your ability to use the Geo-Filter to connect to the best/lowest ping servers. The best servers will be those that are closest too you.
