Ejzerwas
Nov 08, 2022Tutor
No ping heat map
So I can't get call of duty ping heat map to load. No servers show up in the map. But when I target other games servers will show up on the map. No idea where to start to fix this issue?
Dropbottom
Jan 05, 2023Tutor
Please advise
Netduma-Fraser
Jan 05, 2023NetDuma Partner
We have done a cloud update so if you resync the cloud now it should work
- shilton001Jan 17, 2023Initiate
Anyone elses Ping Heatmap not working. None of the servers at all are showing up. Ive re synced, rebooted router and turned off and on to no avail. Anyone else's not working?
- Netduma-LiamJan 17, 2023NetDuma Partner
It looks like we need to push a cloud update, I'll speak to the team and we'll try to get that done today. You should see servers back on Ping Heatmap later today.
