jjw001
Apr 21, 2019Tutor
No smart connect or mu-mimo options
Heads up folks. The brand new XR300 does not have a 'smart connect' option for the wireless settings or the abilty to enable or disable mu-mino. If these features are important to you don't buy thi...
Netduma-Fraser
Apr 21, 2019NetDuma Partner
I believe you are violating your NDA with Netgear by divulging any knowledge you may or may not have about the router given it has not been released yet.
Also given the price point it is a cheaper way to experience DumaOS on a Nighthawk, it is not going to compare hardware wise to the more expensive 450/500/700 as is already shown in comparisons on Amazon for example.
