stephhopper
Jun 19, 2020Follower
no wifi provider
i just got rid of my wifi provider because it was not working where i have moved to so i was wondering if i get a router and modem will it work for my phone and tv for a internet connection without a ...
Jun 19, 2020Guru - Experienced User
Who do you plan on using for internet?
That's kind of key as you need a modem/gateway that is compatible with whoever you plan on using for an ISP.
