rougebaby
Sep 19, 2018Aspirant
No wifi?
Hello guys,
I just set up my router yesterday and it was working prefectly fine which i can connect to the internet using wifi. But this morning, it's not working anymore, does it mean that i h...
Stagg7
I have had the exact same problem this morning was working fine streaming and then all of a sudden stopped and now can no longer connect to the modem just the power light constantly blinking
I havent had a problem with it in over a year then all of a sudden this so im thinking maybe a firmware update but how do i rectify it if i can't connect to it?
Please help
Modem is Nighthawk X4S D7800
Netduma-Fraser
Sep 20, 2018NetDuma Partner
Hi rougebaby, that would indicate that the XR500 has lost internet to the ISP modem. Have you checked the modem to see if you have an internet connection? If you don't then it could be an outage in your area and would recommend contacting your ISP.
Hi Stagg7, I would suggest posting your issue to: https://community.netgear.com/t5/Nighthawk-WiFi-Routers/bd-p/home-wifi-routers-nighthawk as this section of the community is for the XR500 and soon to be the XR700 as well.
