Amg1108
Apr 02, 2021Aspirant
Nord VPN on XR500
Hello, I’m looking to use Nord VPN with my Nighthawk XR500. I keep seeing I need the OpenVPN configuration but don’t know where/how to find it. Can anyone walk through how to set this up?
Netduma-Fraser
Apr 02, 2021NetDuma Partner
You will need to login to your NordVPN account on their website and find the config files, likely in a download section. Then paste the contents of the file into the Advanced Setup on Hybrid VPN
Amg1108
How do I know which one to use?
- Netduma-FraserApr 02, 2021NetDuma PartnerWhat are the options they have given you? You can take a screenshot if it would be easier
- Amg1108Apr 02, 2021Aspirant
- Netduma-FraserApr 02, 2021NetDuma PartnerThat's for you to decide, the first two letters indicate the server country e.g. UK - United Kingdom, NL - Netherlands so depends where you want the server to be
