Mike852's avatar
Mike852
Follower
May 21, 2019
NordVPN on Nighthawk XR500 router
Can I install the NordVPN client on Nighthawk XR500 router? I read some comments about it. Some say that only 'Hide My Ass' client is supported, others say VPN clients are working poorly. I also heard that in the future the new firmware should make it possible.
I have an Asus router now. On that one I only need to enter my login, password and configuration file (which I can download from the NordVPN site) and it works without any problems. How does that look on the Netgear Nighthawk XR500 router?
1 Reply
  • Hi Mike, exactly the same, you'll need to enter the OpenVPN configuration file and you'll be able to use NordVPN with the Hybrid VPN feature.
