Deeox
Jun 15, 2020Aspirant
Normal speeds after reset but after a day goes slow again
I have a XR500 hooked up with a Arris SB8200 and gig comcast internet. For some reason I would get my speeds perfectly then in a day it goes to 30 MBPS!! I've tested the modem and It gets the spe...
Jun 16, 2020Guru - Experienced User
Have you logged into the sb8200 to check the ISP cable connection? you can check that and post them back here.
Have you noticed if wired device loose speed as well or just wireless?
If wireless, is it the 2.4ghz band, the 5ghz band, both?
