Deeox
Jun 15, 2020Aspirant
Normal speeds after reset but after a day goes slow again
I have a XR500 hooked up with a Arris SB8200 and gig comcast internet. For some reason I would get my speeds perfectly then in a day it goes to 30 MBPS!! I've tested the modem and It gets the spe...
Netduma_Alex
Jun 16, 2020NetDuma Partner
What are your expected maximum speeds?
In QoS, have you got Share Excess Bandwidth selected?
Deeox
Jun 16, 2020Aspirant
I have 930/30 ish. I disabled QoS as a whole and it didn't increase.
- plemansJun 16, 2020Guru - Experienced User
try going in and manually setting up the qos bandwidth for your speeds.
Also disable anti-buffer bloat.
have you tried downgrading the firmware a version?
or when the speed slows down, checking your cable connections page?- Netduma-FraserJun 16, 2020NetDuma PartnerDo you see the speed decreases on all devices connected to the router?
