Deeox
Jun 15, 2020Aspirant
Normal speeds after reset but after a day goes slow again
I have a XR500 hooked up with a Arris SB8200 and gig comcast internet. For some reason I would get my speeds perfectly then in a day it goes to 30 MBPS!! I've tested the modem and It gets the spe...
MrCryptoDesu
Jun 16, 2020Aspirant
this happens to me to. It honestly makes me want to commit die every day as I have to restart my router evrey single day because it just refuses to work like any normal router. My router from 6 years ago works fine only problem being it doesnt support my gig speeds. But this one with the same exact setup as op aside form the modem goes from 980mpbs and basically every hour that passes I lose 10% of that speed. Given like 2 days without restarting my wifi speeds across any device will reach like 12 kbps.
- Netduma-FraserJun 17, 2020NetDuma PartnerIf you do a complete factory reset either from the interface or holding the button in the back of the router for 30 seconds, then go through the setup wizard but then don't change any settings do you still get the speed decreases?
- MrCryptoDesuJun 17, 2020Aspirant
yeah it doesnt matter what settings I choose QoS enabled disabled auto channels whatever
- Netduma-FraserJun 17, 2020NetDuma PartnerI mean if you leave everything default, don't touch the interface after a reset does it still happen?
