Deeox
Jun 15, 2020Aspirant
Normal speeds after reset but after a day goes slow again
I have a XR500 hooked up with a Arris SB8200 and gig comcast internet. For some reason I would get my speeds perfectly then in a day it goes to 30 MBPS!! I've tested the modem and It gets the spe...
Netduma-Fraser
Jun 17, 2020NetDuma Partner
If you do a complete factory reset either from the interface or holding the button in the back of the router for 30 seconds, then go through the setup wizard but then don't change any settings do you still get the speed decreases?
MrCryptoDesu
Jun 17, 2020Aspirant
yeah it doesnt matter what settings I choose QoS enabled disabled auto channels whatever
- Netduma-FraserJun 17, 2020NetDuma PartnerI mean if you leave everything default, don't touch the interface after a reset does it still happen?
- MrCryptoDesuJun 17, 2020Aspirant
yeah thats actually the current setting im on right now
- Netduma-FraserJun 17, 2020NetDuma PartnerI assume when the speeds decrease that if you connect direct to the modem they report full speeds?
