kamikazeedragon
Aug 06, 2020Follower
Not getting 1GB connection from x6 R8000 nighthawk router
I recently got 1gbps fiber coming into my house. For some reason, I cannot get above 300mbps out of the router. I don't have anything special setup. I've run tests from a computer connected to the...
Aug 06, 2020Guru - Experienced User
Qos, traffic monitoring, parental controls aren't recommended at speeds >250mbps.
And I've heard of their settings being retained even though disabled and rebooted.
I'd try a factory reset and then during install, only setup the things necessary to get it working. Then speedtest.
