Jmat94
May 17, 2019Aspirant
not getting full veriszon gigabit speed on nighthawk
So heres a quick run down, i have the gigbit speed plan my router is connected straight to verizon network there is no modem in between. im getting reallt spotty speads with this sometimes its 467 an...
May 22, 2019Guru - Experienced User
Most wifi devices will not see anything near 900Mb on speed testing. Depending upon Mfr design and support, most will max out at around 400-600Mb est. If your getting 900Mb thru the router with a wired PC/laptop, then this means the router is working for wired speeds. Wireless speed you'll have to check with the devices Mfr support to see what actual speeds you may get when speed testing over wireless.
I did forget to mention that if you enable 160Mhz on the XR router, and if you have a wifi device that also support 160Mhz on 5ghz, then it's possible to see 900Mb on wifi speed tests.
Netduma_Alex
May 22, 2019NetDuma Partner
Fair point, there might be a limitation on the client device rather than the router.
