modjoul105
Oct 11, 2018Aspirant
Not more than 30 devices able to connect
Hi,
I am trying to connect multiple (around 30) wearable smart-belts to the Nighthawk XR500 router but there is the loss of connection frequently. When I check the logs there seem to be a ...
Oct 11, 2018Guru - Experienced User
Just curious are you using this router for gaming with game consoles and PCs or something else?
- modjoul105Oct 11, 2018Aspirant
Nope. It's just my laptop that I am connecting so I can monitor the logs, and then the 30 wearable devices. The total bandwidth consumption is less than 1 Mbps for all devices combined.
modjoul105
