antigen
Dec 30, 2018Initiate
Not Secure Login entering XR500 router login
Just ran into a recent issue that didn't present itself before.
Before when I would normally enter the router login at http://192.168.1.1, I would log in fine. However, I recently reserved an IP...
Netduma-Fraser
Dec 30, 2018NetDuma Partner
This isn't an issue per se, the router does not store any identifiable information about you etc so don't need to worry about it being not secure. Also I doubt if this suddenly changed as it's always been there as far as I am aware, you just may not have seen it before or it just showed as an icon rather than saying the whole 'Not Secure' message.
antigen
Okay thanks for the quick follow-up
