yurarnd
Mar 22, 2020Tutor
not work geofilter XR300
Hi, I bought XR300 and I have doesn't work correctly geofilter in any game , it is looking for servers and hosts outside the circle of the geofilter, the router is updated to the new firmware, the ge...
MrXrated
Mar 31, 2020Tutor
I'm having the same problem, already issued a refund from Amazon. I wish I could actually get this router to work correctly without having to return it. They should roll out a new firmware update for this model to fix these minor issues. The R-App isn't loading and I'm also get a ton of other bugs.
Netduma-Fraser
Mar 31, 2020NetDuma Partner
Sorry to hear you're returning the router, hopefully when you see DumaOS 3.0 it will have alleviated the issues/concerns you have and you may consider us again.
- yurarndMar 31, 2020Tutor
when does Duma OS 3.0 come out ?
Netduma-Fraser wrote:
Sorry to hear you're returning the router, hopefully when you see DumaOS 3.0 it will have alleviated the issues/concerns you have and you may consider us again.- MrXratedMar 31, 2020Tutor
I might just keep it until you guys sort out the problems. I just downgraded the software to XR300-V1.0.1.4_10.1.4 and it's working without any issues. If I were you guys, I'd look into what you did differently that caused this issue in the first place. The first version of the software works more rapidly and doesn't give any R-App or nil errors.
- Netduma-FraserMar 31, 2020NetDuma PartnerWe don't have a deadline at the moment but we should be doing a beta very soon. Hopefully you'll be able to provide us with some feedback on this during the beta.
