Xedous
Dec 11, 2020Aspirant
Nothing but problems with Nighthawk
Ever since I purchased the Nighthawk I've had issues. Every so often the router will decide that one of my devices does not need internet that day. I check my Nighthawk app, no errors or messages o...
Xedous
RAX45, which now that I'm looking aorund the site a bit see that this forum my not be the place for my type of router. Router is hooked to a fiber modem from my provider, not sure what kind since it's in a locked box on the side of my house.
Dec 11, 2020Guru - Experienced User
this would be the AX forum:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wifi-ax6
might lookup as well to see what fibre modem it is. Some have their own integrated routers.
