Misterswede
Aug 13, 2019Guide
Numera m.2 samsung evo 970 plus 250gb
When I connect this via usb on the router and let Plex search it says “something wrong” and won’t use it if I use an fat 32 usb it works It some media files are over 5 go so I need exfat any ...
- Aug 13, 2019
I know this is the harddrive requirements for nighthawk.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Exfat isn't compatible.
Aug 13, 2019Guru - Experienced User
- Netduma-FraserAug 13, 2019NetDuma PartnerWhich router are you using?
- MisterswedeAug 17, 2019GuideIt worked with NTFS and like the first answer suggested exfat not supported
Many thanks
