Misterswede
Aug 13, 2019Guide
Numera m.2 samsung evo 970 plus 250gb
When I connect this via usb on the router and let Plex search it says “something wrong” and won’t use it if I use an fat 32 usb it works It some media files are over 5 go so I need exfat any ...
- Aug 13, 2019
I know this is the harddrive requirements for nighthawk.
https://kb.netgear.com/24059/What-are-the-USB-drive-requirements-for-my-Nighthawk-router
Exfat isn't compatible.
Netduma-Fraser
Aug 13, 2019NetDuma Partner
Which router are you using?
Misterswede
Aug 17, 2019Guide
It worked with NTFS and like the first answer suggested exfat not supported
Many thanks
Many thanks
