Rick6922
Jul 12, 2019Luminary
OoS keeps crashing!
here in the last couple of weeks I've got anouther problem with the xr700, the QoS keeps crashing. when it does it not only isnt working but it puts my upload and download speed to 1000 up and down...
Jul 12, 2019Guru - Experienced User
Try this, power OFF the ISP modem. Factory reset the XR router. While the XR router is resetting, power ON the CM modem.
With a wired PC connected to the XR router, walk thru the setup wizard. Ensure ALL other devices are turned OFF or disconnected from the router. Check to see if the wizards speed test results return accurate results. If good, continue to complete the setup wizard...
- Rick6922Jul 12, 2019Luminary
FURRYe38 wrote:Try this, power OFF the ISP modem. Factory reset the XR router. While the XR router is resetting, power ON the CM modem.
With a wired PC connected to the XR router, walk thru the setup wizard. Ensure ALL other devices are turned OFF or disconnected from the router. Check to see if the wizards speed test results return accurate results. If good, continue to complete the setup wizard... all I have to do is reboot the router and then the saved QoS settings come back with the right speed. I shouldnt have to do that though!
- FURRYe38Jul 12, 2019Guru - Experienced User
Please try it.
- Netduma-FraserJul 13, 2019NetDuma PartnerI would clear the cache and cookies on your browser as well as its very odd for just this one setting to revert itself.
