Rick6922
Jul 12, 2019Luminary
OoS keeps crashing!
here in the last couple of weeks I've got anouther problem with the xr700, the QoS keeps crashing. when it does it not only isnt working but it puts my upload and download speed to 1000 up and down...
Rick6922
FURRYe38 wrote:Try this, power OFF the ISP modem. Factory reset the XR router. While the XR router is resetting, power ON the CM modem.
With a wired PC connected to the XR router, walk thru the setup wizard. Ensure ALL other devices are turned OFF or disconnected from the router. Check to see if the wizards speed test results return accurate results. If good, continue to complete the setup wizard... all I have to do is reboot the router and then the saved QoS settings come back with the right speed. I shouldnt have to do that though!
Jul 12, 2019Guru - Experienced User
Please try it.
- Netduma-FraserJul 13, 2019NetDuma PartnerI would clear the cache and cookies on your browser as well as its very odd for just this one setting to revert itself.
- Rick6922Jul 17, 2019Luminary
I've already done all that! I've had this router long enough to go through the FW updates that basicly was very unstable. when you and frazer was telling everyone to go back to old FW. lol . my point is you guys say that about 99% of problems so I did that from the start. lol it still does that daily, also the Dumos pages are super laggy if they load at all and yes I've cleared every thing on broswer using crome with over 300mb down and 25 up. and yes it happens if Qos is disabled.
- Netduma-FraserJul 17, 2019NetDuma PartnerHave you been able to try the XR700 beta? There are some newer versions there that you may find better. If you’re not on the beta I’ll ask Christian to add you.
