Rick6922
Jul 12, 2019Luminary
OoS keeps crashing!
here in the last couple of weeks I've got anouther problem with the xr700, the QoS keeps crashing. when it does it not only isnt working but it puts my upload and download speed to 1000 up and down...
Rick6922
Sep 10, 2019Luminary
v1.0.1.8 but my router disconnects from the internet every 15 mins. on that fw. can you add my name to try the new beta if you think it might help.
Sep 10, 2019Guru - Experienced User
See you over on the beta forum. Can post there as well. Let us know how it goes here though.
- Rick6922Sep 11, 2019Luminary
I just got a new 1 over nighted. I hope if nothing else it will run on the og. FW without dropping internet, I would be fine with that.
- FURRYe38Sep 11, 2019Guru - Experienced User
I recommend running the RMA router with out updated FW first to see if its stable.
- ghormanSep 13, 2019Aspirant
My error is NOT hardware related!!!
Good news:
I recieved and setup the RMA router. I didn't import my config file; but I did update to the newest firmware the router requested from its app.
Bad news:
I got this about an hour ago
RPC error 'ERROR_UNKNOWN': bad argument #1 to 'gmatch' (string expected, got nil) -> stack traceback: ?: in function <?:73> [C]: in function 'gmatch' ?: in function 'split' ?: in function <?:137> (tail call): ? ?: in function <?:324> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:290> [C]: in function 'run' ?: in function <?:345> [C]: in function 'xpcall' ?: in function 'try' ?: in function <?:261> (tail call): ? /dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> [C]: in function 'xpcall' /dumaos/api/cli.lua:59: in main chunk [C]: ?
- FURRYe38Sep 13, 2019Guru - Experienced User
I would have tried the RMA router with out updating first.
Did NG support ask you for debug logs? I would send them the logs and this information again. Keep in touch with them about this.
ghorman wrote:
FURRYe38 wrote:I would have tried the RMA router with out updating first.
Problem is I want to use the hybrid VPN feature which is only avaible in the newest release.
- Netduma-FraserSep 14, 2019NetDuma PartnerCould you run the router isolated (not connected to your ISP hub) and see if the issue returns please? Want to see if it's the setup or the router here that's causing it.
- ghormanSep 14, 2019AspirantUnless you want to send me a router for the house then that is not a reasonable option. The xr700 is currently the only router I have for internet.
- Netduma-FraserSep 14, 2019NetDuma PartnerThe ISP hub is just a modem then? Could you do a factory reset on it then please and that should fix it.
- ghormanSep 14, 2019AspirantYeah my isp device is just a modem. The router was factory reset after the firmware update. Before any sets were in place.
- Netduma-FraserSep 14, 2019NetDuma PartnerIn System Information on the R-App panel options change retries from 3 - 5 then reboot the router please and see if that stops the error returning.
